Rebuild of Forester XSN limited edition
So I bought a sad, neglected Forester to return back to former glory.
new hubs all round, new brakes around, replacement engine due to failed water pump taking out the head gaskets by last owner.
currently re-dressing engine bay in readiness of new engine fitting.
So some more work completed,
engine complete except for fitting new water pump, then onto the engine crane to allow new clutch fitting before refitting into the car.
engine bay corrosion all addressed and then sprayed with hard finish smooth black, better than the dull base seal coat from the body shell dip many years ago.
new clutch release bearing fitted, new clutch braided hose fitted and full flushed and bled through.
Uprated rear gearbox/engine support mounting billet fitted, to uprate the floppy standard mount.
getting close to get the lump back in the hole.
new fuel filter and re-work of the entire filter housing to be done prior to refitting.
So engine all in and burped with new coolant,  first start up since install done
Decided with decent weather, to G6 compound the whole exterior and then machine polished to glass finish!
Nice work, looks great 🙂
  • 2 months later...
Been busy under rear end got 4 wheel alignment completed, and looks nice and tidy
Moved to the drivers seat area, with a forester tourer 2012 dash swap as the push start system avoids any immobiliser issues, a tidy steering wheel and it looks so much better
So passed MOT car driven first time in a year, had to get a front anti roll bar link as it was a bit iffy, got new h/duty ones ordered, couple of jobs still yo do, Powerflex rear subframe bush inserts to fit…… and then all fluid changes after a couple of weeks to flush out the systems.
anyone recommend best flush oil for the diff’s and gearbox?
cheers Rob
Well car is running and pulling well, just need to swap out the gearbox and fit big front brakes so I can actually stop, originals are very very poor!
  • 1 year later...
Car progressing slowly due to my health, but found a none rotten rear subframe so time to start the clean up and then full rebuild and transfer of it to the car to extend it life.
  • 9 months later...
Got some nice STI SH9 Upgrades from Japan and full hard race roll correct with set of almost new wrx garb alloy front lower arms to enhance the from end, so some fitting of bits to now fit in when we’ll enogh
New rear subframe with all new arms, bolts and hubs almost ready to transplant into the car, that will hack the mot tester of as he won’t be able to rust rear subframe comments anymore!
