Fast Idle issue 2004 impreza
Hi,
I was wondering if anyone can help with my 2004 Impreza. I recently took the throttle body off to clean it. Now when starting it idles high at 2500RPM and doesn't drop, I also have a trouble code P0519 for IACV performance.
I have checked the wiring all looks good and I have replaced the IACV. I've also replaced the gasket for IACV and throttle body.
I also can't find any vacuum leaks.
Any help would be massively appreciated!
Thanks,
Chris
Hi Chris
Sorry to hear you are having a bit of trouble. On my legacy I tried the throttle position sensor just to rule it out, but it sounds like your IACV isn’t closing. Was it brand new or second hand?
It might benefit from a good clean with brake cleaner and some pipe cleaners if it’s a used part.
I hope that’s of help.
Hi David,
Thanks for the reply I have tried cleaning, but no luck. The IACV was a refurbished part (new gasket obviously).
Maybe TPS like your saying, but voltages don't look to far off.
I'm taking the Impreza to Triton Motorsport today to have a look, so fingers crossed.
Thanks again
Triton will definitely be able to sort it out, they have some great experience.
yeah they were really good. Turns out the refurbished part I got didn't work either 🙄 thanks for the help
No worries mate, I had a similar issue with mine and it took a lot of cleaning to get it working.
