Legacy Bucking/Missing
I have a 2016 Legacy for about a year now and it suddenly started bucking between 1000 and 2000 rpms. Its fine below and above that but bucks and stutters otherwise. I cleaned injectors, checked plugs and coils and they seem to be fine. No check engine light comes up either. Any thoughts on this?
7 hours ago, Greenmamba said:
Maybe tps?
Please explain...no idea what that is
Throttle position sensor. You have a drive-by-wire system which means the throttle is measured by electrical measurements of how far the accelerator pedal is depressed, thereby operating the engine speed electrically (used to be cable connecting the 2). It could have developed faults, meaning the pedal movement isn't being translated accurately. If it's the problem, replacement of the tps may be needed.
Thanks man...will check that
