seatbelt beep
i've just picked up a 2007 outback, very pleased so far. To disable the seatbelt beep ive read you insert remove the seatbelt latch 20 times, ive tried this several times but it doesn't work BUT what i have noticed is sometimes the seatbelt beep comes on when i have the belt on so the switch maybe worn. Can the beep be disabled using say the rear seatbelt as they should be less worn?
cheers
carl
17 hours ago, Dr. Acula said:
I do wear a aeatbelt but ilke the option of not wearing one when driving on campsites etc I've tried the buckle unbuckle 20x thing but doesn't work
