Very low clutch biting point
Hi all. My '09 Fozzy 2D has a very low clutch biting point, almost to the floor! Is this normal or is there any adjustment in the pedal?
That out of spec, you can adjust the pedal from under the dash which might improve biting point but if clutch well worn it may not give results you hoping for .
Clutches on these don't hold out great & quality clutch is spendy job
Thanks Mr B, I'll try adjustment.
