EGR valve 2013 2lt P0409
Hi,
Hopefully someone can help me please!
I got 3 warning lights on the dash-
engine light, electronic park brake and flashing cruse control and the code p0409 on the code reader (exhaust gas recirculation sensor A circuit )
So I have cleaned the egr valve and tried again but lights and code come back.
EGR moves freely now and motor works when I apply power.
Not sure what to look at next  ?
is there a sensor in the egr or ?
Other codes that come up are P0401 (resurculation flow insufficient detected)
& P0403 (Exhaust gas Resurculation control circuit)
Also does anyone know which fuse the egr runs on ? (as I haven't found a detailed enough diagram.)
Thank you in advance
Simon
Sorted it out 😀
I figured out the spring was broken so that is why it was not working.
I put the new one in and all error lights and codes went away by themselves.
All the best, maybe this will help someone else
  • 7 months later...
Hi
I have the exact same problems. What spring did you change? Location?
R
Hi,
There is a spring in the egr valve so you will have to change the whole valve I think.
But also worth opening it and trying to clean it first as it might just be stuck if you are lucky as a can of egr cleaner is much cheaper than a new egr valve.
