Subaru diesel xv 2012 dpf
Vehicle has done 97000 miles  All warning lights came on, garage #1 couldn't read the computer despite being able to in the past, garage #2 did a service but couldn't do dpf regen as couldn't communicate to that module and concluded the car had a faulty tcm module, advised to take it to a subaru garage. Took it to Subaru garage who informed me that their software wouldn't be able to connect to the car as the car was now too old! Via via got directed to garage # 3 who COULD read the vehicles computer, then did a forced regen but lights were still flashing, told me to drive it home on the motorway, 5th gear, high revvs etc and that the lights would go out one by one once the regen was complete. They didn't. He also told me the problem would remain as the dpf was finished and needed to be replaced or removed. Garage # 4 also advised removal and has given me contact for a professional that can do a delete. Garage #5 plugged in and told me that the lights would not go off after a regen if other filters, oil etc wasnt cleaned after doing it. He reckons there could be a fault with the sensors... now booked in to do a regen with him. The car is driving fine. I have driven it several times on the motorway to try get it to do a regen and burn off the soot. It's running on good fuel since the problem started and its had 2 bottles of dpf cleaner. I read online that dpfs can be completely removed and thoroughly cleaned like new, is it worth it? I see new ones online for approx £300. Is a delete the way to go? Should I get my own diagnostic machine? What's going on here? Any advice most welcome
When I was having sensor issues on my 2008 diesel I went to a diesel specialist in Milton K (from memory AW Diesel).
They didn't find the issue but we're good enough to direct me to a place with a rolling road (from memory Marlin Motor engineers).  They were able to diagnose it as the MAF.
The location probably doesn't help you but it might be worth finding a rolling road and/or diesel specialist.  They might be able to clean or delete the DPF.
Hello Sue - I have had the same issue with my XV. I borrowed my mates launch diagnostics kit and found no issues with the DPF. It just turned out to be the oil dilution warning, which can be reset very easily. Hopefully it’s the same for you.
