Fuel cut off after hard cornering
Hello All,
So recently changed the Fuel pump from standard to a walbro 255lh - noticed after exiting corners the car briefly cuts out as you throttle for the exit (track car)
Is this a fuel reg problem, or is the new pickup filter bag on the pump crap? It is smaller than the original bag.
Car has well over half a tank of fuel.
Cheers
I would doubt its oil as you wouldnt get a drop in power unless the engine blows itself up, i would lean more towards fuel starvation caused by the cornering. I would try it wth a totaly full tank vs a low tank and see what you get, may need to baffle the tank.
