Rear Subframe
Hi All
Any idea if rear subframe bushes are available anywhere. I've finally got the subframe off and removed the rust and it would seem sensible to replace the bushes but can't find anywhere stocking them-ICP first port of call but nothing on there. I did read/hear somewhere (YouTube possibly) that they're no longer available.
Regards
Paul
Don't believe too much of what you get told via youtube or facebook lol .
Still can get these and original subaru part 20174AA020 not expensive
https://www.ebay.co.uk/itm/283764755433
https://www.importcarparts.co.uk/product/floating-bush-rear-sus-bed-20174aa020/
https://www.amayama.com/en/part/subaru/20174aa020
Other options are polyurethane bushes but they will be more cost than OEM .
https://www.strongflex.eu/en/polyurethane-bushes-subaru-legacy-ii-outback-i-bd-bg-bk-1994-1999/1821-271801b-rear-crossmember-bush-5902553552584.html
Just be sure your subframe proper solid, if good I would paint it with zinc rich epoxy then some tough ox or you could do a  black wax coating like dinitrol products (if wax based coating most of it need doing after basic fitting steps or too messy handle)
I done a few with Dinitrol ML then Black waxoyl or Dinitrol 4941 black wax and if done with some thought and care it can look like new, have a low cost and long term rust control with easy topup maintenance if needed .
Thank you once again for your sound advice-I will certainly do as you suggest. I found the strongflex site after I posted this query-looks promising-have you ever bought anything from them.
On ICPs "wishlist" for a complete set of bushes and fixings for rear suspension but that was several months ago so still waiting on that.
Thanks again and much obliged.
Paul
Have used Strongflex before for front rear trailing arm bush and front wishbone front bushses and they seem as good as any other known brand.
They use to be quite cheap via eBay or direct off site but prices gone up with brand recognition I guess and global hassles adds a cost  ...
