which trim
How would i be able to find out which trim i have? what package did ,,sport" have ?
your code from the vin plate should give some idea, photos of the interior may get an answer from a member on the forum but probably a call to subaru would get a definitive answer
alrite then, if i snap a picture of the vin plate would someone be able to tell me then?
possibly - I know some work has been done to reconciliate all of the various trim options to the code number but I dont know how extensive that was.
photos of the interior may give some idea also??
ok would this helps then ?
post-1681-0-74060000-1386423396_thumb.jp
post-1681-0-62132900-1386423406_thumb.jp
post-1681-0-58630400-1386423416_thumb.jp
post-1681-0-64127100-1386423431_thumb.jp
post-1681-0-86599700-1386423444_thumb.jp
from the interior it looks like an MY04 model
you should have a code like this on your vin plate
GDAE48D
GDAE48T
plug it into this web page and see if it generates a result
http://scoobyprojects.co.uk/technical/appliedmodel.php
also this may help with the VIN breakdown
http://www.cars101.com/subaru/vin.html
That dash is from a bugeye it seems to be a few cars looking at it :D
this is where my knowledge is being added to as I go along...
I thought the 04 blob had the same dash as the bug from 02 then it changed with the 05 model blob?
Could be right I was going on the blobeye in the garage but it's a 55 plate I thought all Blobeyes came with the same dash :)
the seats not the same as either my bugeye or the blobeye same with the steering wheel
Mine ιs a 05 ɑnd ɑnd has the same dash but Ιt was late registered! My mates ιs also 05 but has the newer dash!
Oh never knew that I just thought they changed it with the blobeye :) Mind you I was looking at a hawkeye at the same time as the blobeye
didnt the STI's have a different steering wheel as well or was it just all 05's on with 3 spoke and sti badge in centre?
Yeh sti's have different wheel bud, don't lιke the wheel in mine tbh though my other cars wheel was only 270mm!! Scoob use one feels lιke ιt's out of a bus lol, don't want to lose the airbag! Didn't matter in the other car with full cage buckets ɑnd harnesses
ok how about this?
B83E8D2F-061F-41A6-B767-F69A7B60ACDB_zpsJay- i tried to use that code finder but didnt work mate
so what i worked out is that colour is Pacifica blue :)
done some digging all I could come up with is the following info... can only suggest contacting Subaru directly
found this on scoobynet.com for some reason it comes up in Polish??? even if you cahnge language to English but you can understand it.
2480C941-C84A-4321-A361-C171A11115F9_zps
i also dont understand why it says Reddish-Blue cos if you google 23W subaru it comes up as Pacifica blue, Oh and last thing- 115HP ??? is that it ? :huh:
thats the polish for ya :D
:blink:  :ph34r:
