Tyre Pressure Help.......
I've got 235/35/19 tyres fitted to my 2002 STI
What pressure should I be looking at for these ?
If anyone can point me in the direction of a set of gold 17" id be very grateful
I run 30psi rear 32psi front, this on 17" though.
If you can get the tyres filled with nitrogen rather than compressed air. It's an inert gas so doesn't expand when heated. Means the tyre pressure is constant. Most Kwickfit and ATS can do this.
Hi mate welcome to S.O.C
And as Pete has said is about the right pressure Rears should be a bit less by about 2 psi. But I do just put 32 psi all round.
I was gonna go 33 on front 32 rear
Thats should be fine mate with being bigger I have  255/35/18's on mine.
