brid Posted December 31, 2013 Posted December 31, 2013 Hi All Thinking of getting an Impreza Diesel but currently owning a couple of diesels at the moment I have a few questions on DPF filters and servicing, If anyone could help? I currently own a Freelander 2 and a Fiat Bravo. Both are deisel and both have DPF filters but they both handle things in a different way. The Bravo is the best of the two with the DPF problems but that is the one I would sell to get the Impreza. I do long journeys but have periods of just running about which can cause the DPF to block of which is not a problem if you know what to do to unblock it. The Bravo puts a light on the dashboard warning you that the DPF is blocked, you then put it on the nearest bypass at about 50 to 60 mph for 10 mins and it runs a regen and all is fine for a long time. The Freelander 2 is different in the fact that it will have three regen attempts in secret so to speak and if the third regen attempt fails for some reason the limp home engine light comes on and it's a visit to the dealer to resent things. This is annoying with the Land Rover as if it told you what was going on like the Fiat does you could take it for a longer run to sort things out before the dealer has to get involved. This only happens once ish a year as the long journeys stop any of this from happening but it does happen if my work changes to where I live. My question is what happens on the Impreza Diesel when the DPF gets blocked? is it like the Bravo or the Freelander 2?? Do any of you have any experience of this happening? Cheers Brid
Gambit Posted December 31, 2013 Posted December 31, 2013 I've never had a diesel so couldn't tell you mate sorry :( I'm guessing it's the hatchback impreza ?
brid Posted January 1, 2014 Author Posted January 1, 2014 Yes the hatchback although the same engine would be used in other Subaru models as I think there is only 1 diesel
Jay762 Posted January 1, 2014 Posted January 1, 2014 unfortunately I dont know about Subaru diesels but the expereinces I had with the DPF on my merc van were sorted when I had a service using BG products along side the regular oil change, the engine and pipework were all cleaned out the DPF cleaned out and now I use a bottle of the BG fuel additive in every tank of diesel - had no issues since
brid Posted January 1, 2014 Author Posted January 1, 2014 Hi jay Do you add it everytime? Which one is it?http://www.bgprod.com/products/diesel.html What type of diesel do you put in normally? Stuff like Shell nitro or supermarket own? Thanks
Jay762 Posted January 1, 2014 Posted January 1, 2014 I di it every time but to stretch it you could do every other time - Im not fussy about the diesel so will use supermarket stuff or standard BP Shell etc, the product has all the additives and cleaners that you would find in Shell nitro diesel The stuff I use is product number 2276 - BG DFC with Lubricity After having the service done I noticed an improvement in throttle response and reduced engine running temperature it dropped from an indicated 100 down to 82 :o the black sludge that was coming out of the exhaust is no longer there - there would also be better fuel economy for a slightly less spirited driver :D so the flush followed by the continued treatment has kept things clean
brid Posted January 2, 2014 Author Posted January 2, 2014 HI Jay Where do you buy it? I can't find it for sale on the internet Regards
Jay762 Posted January 2, 2014 Posted January 2, 2014 it is normally through a dealer - I have a mate who sells it - ill ask him for his contact in the NW (its all done regionally)
brid Posted January 5, 2014 Author Posted January 5, 2014 Thanks very much for your help Jay Just need the impreza now!
Jay762 Posted January 5, 2014 Posted January 5, 2014 the product and DPF treatment will work for all diesels ;)
david1972 Posted March 3, 2014 Posted March 3, 2014 Interesting reading this....especially as subaru seem to be having a big push on the diesel models for foresters and outbacks. I swore I'd never get a diesel again after the DPF issues I had with my Qashqai. If this really is as good a solution as you suggest, I may need a re-think in future years
brid Posted March 3, 2014 Author Posted March 3, 2014 Hi David I think diesel is the way to go if you want 4x4 . I am still going to get an Impreza Diesel but currently still driving my Fiat Bravo, If it works it does sound like a great solution but I just really wanted to know how the Subaru Impreza tells you when the DPF filter is blocked and as a driver is there something I could do to unblock it (as I can do now with the bravo but NOT the Freelander)
david1972 Posted March 3, 2014 Posted March 3, 2014 Yeah, my QQ used to have the same feature as your bravo....warning light that was solved by a dual carriage way cruise or 5 mins in 2nd at 40mph lol. Very annoying, regardless Sent from my iphone using Tapatalk
Jay762 Posted March 5, 2014 Posted March 5, 2014 If the DPF is the show stopper but you really want the rest of the package get an ECU mod and remove it completely??
david1972 Posted March 5, 2014 Posted March 5, 2014 Wouldn't that get picked up at mot though? My knowledge in this area is limited I'm afraid, sorry Sent from my iphone using Tapatalk
Jay762 Posted March 5, 2014 Posted March 5, 2014 as modern diesels have cats as well if the rest of the engine is in good nick you wont be throwing out high emissions
5heffield 5ubaru 5ervice Posted March 8, 2014 Posted March 8, 2014 Be careful on the subaru diesels as they suffer with injector blow by which causes excessive carbon build up in sump and blocks pick up pipe which in turn causes oil pressure failure and knocks cranks out and engines are expensive and not many parts available to rebuild cheers martin sss Sent from my GT-I9305 using Tapatalk 2
5heffield 5ubaru 5ervice Posted March 8, 2014 Posted March 8, 2014 As far as I am aware u have to force dpf regen with subaru tester I am trying to get software through launch to be able to do it but not possible yet am affraid and make sure you reset oil dilution after oil and filters Sent from my GT-I9305 using Tapatalk 1
Register a new accountSign in
