turbo not holding boost
Hi I have a 2003 bugeye wrx and my boost is not holding?
You can hear the turbo spooling and dropping about 3 times before holding on full boost?
Have checked all pipes and replaced a couple if anyone could help as really annoying
Thanks dan
could be not spooling up - worn bearings, actuator not working / leaking which means will not come up to full boost steadily as boost will be bled off
leak some where bleeding boost off
do you have a variable boost device fitted that could be failing also?
are there any engine fault codes being generated?
No verible boost and no fault codes
And have taking all intercooler off n.checked all pipes
And turbo defo spins up as can hear it and feel ir boosting then drops acouple of times
Might have to try actuators as a couple of people have said that
