Help Poss HG issue
Ohhh yeah I'd be a bit worried knowing that :( If I did risk it and it is a risk give it a full check to the point you **** him off because you check it all. Unless it comes with full paper work of work carried out and the damage listed I.e a trusted Cat write off :(
best go scare that lady down the road I think :D
apparently the guy that found out about the write off said the seller pleaded ignorance saying he knew nothing about it, also someone said they have a high turnover of classics and the one you see in the pic may not be the one you see when you get there, all seems a bit dodgy so i think i'll be giving them a wide birth
Ouch yeah that would be enough for me to run a mile :)
was looking at his cars for sale again last night and there was a guy on facebook said he had bought one of the white classics, i did notice he'd gone from selling two to one, then last night there were two again, the new one that had appeared was the same one the facebook guy bought, i did a reg check on both white cars and both were registered as silver, looks like he's getting a WIIIDDDDEEEE birth from me
just incase anybody else comes across them heres the link
ebay link
Another ebay id to be avoided - might be worth its own thread at this rate
Agreed and not to try start a debate but the name with the dodgyness of the cars doesn't after the last ebay member that is a bit of a wide boy
Just bit of an update for everyone garage have said they are prepared to do work themselves under warranty. Car is going in 2moz for proper inspection by themselves. To be honest don't really want them working on engine but I have to give them the opportunity to inspect properly and sort themselves. Ideally want them to make me other for contribution so can go to a specialist for work done as even if they do the work themselves I'm still going to have a rebuild with specialist to make sure all done right. Saves wasting their time and mine?
Well thats good to hear at least they will sort it, but think they have too really. As for rebuilds depending where you want to go and a bit of a travel but Martin in Sheffield or Tlag and Bip in Coventry other than Scoobyworld in Leicester only people I would let do mine now . But you might know others thats just from my personal choice :)
Brian at cams in Blackburn Lancashire too
Sent from my Nexus 7
That is a great result, good to hear they will at least look to rectify the issue, gives you time to look about and decide who you would like to complete the higher spec rebuild
Is a few around in Lincoln but I've not heard good or bad reviews from them.
