Forza 5 Top Gear Test Track
  • Replies 64
  • Views 7k
Can't get away with anything :)
You didn't play around with the diff or tyre pressures did you ? I just couldn't keep up at all on the straights you was leaving me even with getting a perfect corner, not sure if the ABS was assisting with a better line out or not but was almost like the car was light or had better torque.
No mate I never mess with the diff as I haven't got a clue what to do or tyre pressures. Only thing I use is near ratios but obviously didn't do that.
I'll try without abs later that will be fun
I wish they would invent wet weather tracks like they had on pgr 3 and 4
I don't think it's the ABs , it could be that on tight corners I use handbrake then get all the wheels spinning on the exit othewisr I find it dies on low revs
Yeah I must admit I was thinking be cool with wet weather on the game. But I can live without it if it means the cars have to keep look that good :D Not sure I will use the handbrake if I knacker a corner up :)
Think mines 1:24.700 so very close. I got mad in the end yesterday and did some career mode in the end :)
its annoying me, I tapped a cone with the rear and it messed me up so got annoyed and played bf4
Yeah I either over cook a corner or get a wheel off and that it game over for a lap sometimes two :(
I find with five it lets you go more across to the right in this one as long as you don't go across to early into the corner.
I will jump on tonight and have a go at this, certainly up for a challenge  ;)
Best I can do for now....
post-2084-0-52510300-1394571392_thumb.jp
Not a bad time mate will get it added tomorrow for you will sling you an invite too on live
Scooby Pete is going to have to try get some time in :D bottom again mate :(
