manual boost cobtroller for amateurs
Hi, please can some one tell me in very simple terms how to fir a manual boost controller?
Simple ..... Don't !!
Your engine will most likely go boom mate ( speaking from experience )
Lol, thanks for the reply mate& this is my first impreza so still learning, I would leave it off but it was originally fitted and was running around 1.5 bar and went like a bat out of hell but I though it was dangerous running 1.5 bar so took it tk a friend who has an impreza and they said you can remove it but now it is dirt slow and runs about 0.5 bar lol and it now runs lumpy as if it was misfiring?
Must have a leak somewhere
What mods has it got ? No respectable tuner would of mapped it with a manual one
They can run 1.5 bar but that's a limit on standard internals . Shouldn't go much more
Problem fitting a boost controller like that is if your car isn't mapped for. 1.5 bar the ecu doesn't know so therefore it will run lean or over fuel to like a limp mode state
Not saying it can't be done but it can if set up right with ecu flash software and det cans etc but takes forever
Thanks mate, it has td05 turbo, front mount intercooler, induction kit, super chip, uprated throttle body and am uprated fuel pump but that's it, where would it leak from?
Super chip ? You know what make ?? Has it been mapped ?
I 2nd that I have one in the car the one in the picture. I disconnected it after reading some horror stories less than a week after I fitted it. Worked well but I didn't want to risk it.
my advice is avoid, mine came with one unfitted and i toyed with the idea of getting a nice cheap bhp increase, however i turned up at a local tuning company for a T piece.
He had a 450bhp GTI R sat out front that hadnt moved for a while and when i queried why this was his response.
Fitted a blitz in car boost controller ( more expensive than manual) and after fitting my stage 2 turbo took it for a spin with a slight increase in boost. turned around and booted it and it spiked to 1.8bar. his turbo went bang as did the head on the engine.
I turned around and went him and binned my manual controller. If you want something doing do it right, £15 for the sake of 40-60bhp sounds great on paper, but is it worth £1200 + for the sake of a new engine and turbo.
Hi, thank you for all your help, it's now running great, the manual boost controller is fitted but it's turned right down so only boosting to about 1.1-1.2 bar.
Nice one mate Just dawned on me why you asked about fitting it now :D sorry mate. You will need to get a profile picture done I recognise them more than names now :D
