Problem when upgraded rear brakes on 2002 wrx
Hi,
I have a 2002 wrx and recently put brembo breaks onto the rear of my car and replaced the rear discs for bigger ones. They fitted fine no problem, bled the brakes but went on a test run and noticed my abs light is on!!!!
Also my hand brake is none existent I was wondering if I would need sti hub and or hand brake shoes and hand brake parts (don't know if they are bigger)???
Thanks for any help or advice
Wotcha and welcome - sorry cant help you with this one but hopefully someone will be along with the necessary info
Thanks for the welcome.
Hi mate welcome to S.O.C
I've seen people do the Brembo upgrades and not had to do that before so shouldn't need to. I would give the contacts a bit of a clean on the ABS sensor and have a play around with it as long as it's not damaged should go away. It was definitely Pads and discs made to fit the Brembo brakes ?
You could also try adjust the Pop out the rubber cap. Use a screwdriver to rotate the adjustment wheel and try to adjust the same amount on each side. You will have to experiment with which way to rotate the adjustment wheel. Do a small amount and pull up the hand brake to see if the brake catches. Repeat until the lever pulls up nicely.
If you can't get enough adjustment that way, you will have to adjust the cable at the lever. Hope that helps :)
Cool thanks for the help
You're welcome hopefully be sorted so you  can take advantage of the nice weather and the dry roads ;)
