hesitant
I would have taken idle valve off but aint got a new gasket.:(
I cleaned icv definitely idols better. Again still feels as tho she holding bk. I gave her some s@#t boosted fine. I do get engine light intermittently comes up knock sensor ordering one Friday would that affect it..
Yep it will retart the timing if it thinks it's knocking or even put the car into safe mode to stop anything bad happening.
New knock sensor then
New knock sensor ordered should be here Wednesday so ill let you know how it goes. .
New knock sensor come today. Out at the moment but will be putting it on tonight. Dark or not lol
Right got the knock sensor fitted just now right i have got a v5 ecu of a mate he said it's chipped I've fitted it and took it for a test run boost up to 1.0 bar my one a 3b went to 0.8 will the v5 be ok or shall i just put mine bk in
Not sure mate, I'd start another thread to have more knowledgeable responses, if it's uk to uk then I don't see it being a problem,
It will cut fuel before anything goes pop though :-D
It's import to import of a 95 mine a 96
I've put mine on for now till i get some info
  • 5 months later...
Right I'm having a bit of a performance issue. When i boot it she feels dlow accelerating and boost is slow..any idea's. What should i check
I do have a code on ecu reading throttle position sensor 34 i think
