abs!
Hi guys. My abs light keeps intermittently flashing when I'm driving. And the Rev and speedo needle keep dropping to the bottom stayin there for couple of seconds the rising back up!! Don't know if this is due to the same problem!? Help!?
Helpful....
Is the car driving okay or is it in limp mode?
Have you any cel lights come up even briefly ? May be worth checking the codes anyeay see if there are any historical ones.
Have you checked brake fluid levels ? Or has there been any work done one the car recently ? I'd also check the abs fuse make sure it's not on it's last legs.
As for the speedo needle i have no idea.
