Help us build a current list of Subaru specialist garages and repairers - add your recommendation in the thread below
General enquiry
Hello members - i recently purchased my WRX 2.5.. 2006, does this happen to anyone else car starts fine - but after 2,3 seconds she develops this low knock noise then goes away after 10 seconds or so.. should I be worried - she’s the correct oil level etc..
Its hard to say - is it a knock or a tapping noise?
Top of the engine or lower down?
When the engine oil is due to be changed I would use a quality (OE spec) oil filter and it would help to flush the engine (an additive or detergent that breaks down carbon build up) and then replace the oil with a quality oil (Castrol, etc)
Hi mate - so think we have ruled out rod knock thankfully… discovered two sections of centre exhaust cut out (squares cut out) not sure why but mechanic thinks this may be the issue on cold starting I’ll be sure to confirm
