Martin959 Posted July 20, 2014 Posted July 20, 2014 What differences are between a WRX and an STI from the 97 (or 90s...)? The block still the same, right? The only changes are in the turbo, and the gearbox... and suspension I believe... If someone starts modding a WRX, can quickly become superior to an sti? (changing turbo, exhaust, air intake, etc...) Thanks folks! :D
Nevell Posted July 21, 2014 Posted July 21, 2014 I think sti have updated diff,s prop shafts ,forged internals bigger tmic, better turbo ,and more I think they recommend not taking a wrx over 330 bhp But a sti will take 500 bhp For reliability reasons ,me thinks safely 1
Martin959 Posted July 21, 2014 Author Posted July 21, 2014 And now the big question, this can be improved even better than the STI (wrx + mods > sti > wrx) with some mods?
savage bulldogs Posted July 21, 2014 Posted July 21, 2014 Generally uk turbo's and wrxs are the same (bar trim and jdm have short ratio gearboxes) Main advantages of buying a classic sti over a wrx or uk turbo are that the sti's have ... Bigger turbos/ injectors Forged pistons (good for 380 hp ish) Better handling (30 mm lower with sports shocks) Better trim /seats . With just a decat , filter and remap you'd expect 290 ish from a good wrx . With same mods on a sti your see more like 330 hp . Due to internals , cams , turbo and injectors . 2
Martin959 Posted July 21, 2014 Author Posted July 21, 2014 So, having an wrx, you can still buy a even better turbo than the sti, change the piston to forged ones (as far as I know the wrx also have forged ones...), buy some better suspension (hks maybe?)... right?
savage bulldogs Posted July 21, 2014 Posted July 21, 2014 That's what I did [emoji6] As I couldn't see the point paying the extra premium a sti commands and ruining a classic sti , when I wanted to build a forged engine and fit a 6 speed eventually . If your aiming for over 350 hp you have to upgrade the classic drive train turbo , injectors and engine internals (to keep it reliable). Newage is different story as the jdm sti bottom end will cope with 450 hp and the oe 6 speed will handle more than that .so just injector , turbo and cooling mods needed to break the 400 hp barrier [emoji6] 1
Martin959 Posted July 21, 2014 Author Posted July 21, 2014 That's what I did [emoji6] As I couldn't see the point paying the extra premium a sti commands and ruining a classic sti , when I wanted to build a forged engine and fit a 6 speed eventually . If your aiming for over 350 hp you have to upgrade the classic drive train turbo , injectors and engine internals (to keep it reliable). Newage is different story as the jdm sti bottom end will cope with 450 hp and the oe 6 speed will handle more than that .so just injector , turbo and cooling mods needed to break the 400 hp barrier [emoji6] I have a CG8, its hard to make fit the 6 speed manual transmission? Thanks mate :D
savage bulldogs Posted July 21, 2014 Posted July 21, 2014 Straight swop if you find one with the same ratio as your existing rear diff ,you just need the 6 speed.... gearbox Prop Linkage/ gear stick It will mate up with the 5 speed clutch , flywheel and starter no problem [emoji6] 1
Tlag Posted July 22, 2014 Posted July 22, 2014 The big problem with a 6 speed is finding one at a good price :) 1
Martin959 Posted July 22, 2014 Author Posted July 22, 2014 Ok, so I found a gearbox, rear diff, etc. from an STI RA CG8 that will fit apparently according to the owner of the garage... what do you think guys? :) (its a 5 speed gearbox)
savage bulldogs Posted July 22, 2014 Posted July 22, 2014 It will be a short ratio jdm box and if it's a late gc8 sti might even have dccd . But it will only be good for the 350 hp mark . If you google your ty52... code on your existing gearbox you might find that it's the same ratio as your existing box and not have to change the diff . Unless you want to upgrade the shafts and hubs to the r180 later gc8 set up tbo I recon you'd be better off with a 5 speed bugeye box as they're known to handle slightly more power (390 hp ish ) and cost a 3rd of a 6 speed . 1
Martin959 Posted July 22, 2014 Author Posted July 22, 2014 haha whats dccd? :P Well... its quite cheap all, around 400 pounds including changing it, but you think that it wont handle more than 400 hp that one? I mean, its an STI RA gearbox... :P
Martin959 Posted July 22, 2014 Author Posted July 22, 2014 Also, I wont be "stepped on the gas pedal" the whole day... xD so, maybe having 400+ hp, but really using them once on a while... wouldnt hurt i guess :P
savage bulldogs Posted July 22, 2014 Posted July 22, 2014 Direct center control deferential allows you to control the power from front to back , but you have to fit its separate ecu , clocks, wiring and controller . Sti ra's have been around since 95 so it depends on the age and condition of the box . I turned my 5 speed into a 4 speed @ 3k running 330hp , but if your current box is knackered £400 fitted is a great price
Martin959 Posted July 23, 2014 Author Posted July 23, 2014 Also, which could be a good turbo upgrade, from the stock turbo? I was thinking about this one... http://www.ebay.co.uk/itm/Kinugawa-Turbo-Turbocharger-TD05H-18G-AR-8cm-w-3-cover-T25-Flange-370-HP-/130681418855?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1e6d383467 What do you think guys? :)
savage bulldogs Posted July 23, 2014 Posted July 23, 2014 I've been thinking about fitting a kinugawa turbo as they're made by kamak (they make the mitsi td series from new) With that particular one you'd need to change the intake pipe as well cos the turbos got a 3" entry cover 1
Martin959 Posted July 23, 2014 Author Posted July 23, 2014 I've been thinking about fitting a kinugawa turbo as they're made by kamak (they make the mitsi td series from new) With that particular one you'd need to change the intake pipe as well cos the turbos got a 3" entry cover I will have to buy another intake? Do you have any sample? :P
savage bulldogs Posted July 23, 2014 Posted July 23, 2014 It's just the drilled suround around the entry to the turbo ( anti surge) . It makes the need for a bigger dia intake pipe. I think they sell 3 " intake pipes , but you might need to fit a catch can due to them not having as many breather take offs as the oe size ones [emoji6] I was gonna drop them a email and get them to build one that suits my needs , but I can't afford it at the moment [emoji19] Mabye a tdo5 18g , with a 7 cm hotside (like the oe tdo5 16g) with a billet wheel and upgraded journal bearing for a 2ltr fast road car with standard internals . I'd have thought that with the right upipe, that would spool nicely and hit 350 + hp . [emoji16][emoji33][emoji12] 1
Martin959 Posted July 23, 2014 Author Posted July 23, 2014 It's just the drilled suround around the entry to the turbo ( anti surge) . It makes the need for a bigger dia intake pipe. I think they sell 3 " intake pipes , but you might need to fit a catch can due to them not having as many breather take offs as the oe size ones [emoji6] I was gonna drop them a email and get them to build one that suits my needs , but I can't afford it at the moment [emoji19] Mabye a tdo5 18g , with a 7 cm hotside (like the oe tdo5 16g) with a billet wheel and upgraded journal bearing for a 2ltr fast road car with standard internals . I'd have thought that with the right upipe, that would spool nicely and hit 350 + hp . [emoji16][emoji33][emoji12] Did you saw this on eBay.co.uk? can you shaaaaaaaaare the link.... :D :P
savage bulldogs Posted July 23, 2014 Posted July 23, 2014 No I haven't seen it for sale just looked through all of their tdo range and took the most suitable bits and made a list . They do build bespoke turbos or have options that can be added to their range . They're fairly helpful from what I've read , but I've also heard of people being hit with a import tax bill .As with all things imported if their not marked up in your favor [emoji6] 1
