which induction kit
could anyone tell me which imprez induction kit will fit the 2003 (mk3) 2.0l n/a legacy, thanks in advance xx
you'd be better finding one specially designed for you ride matey.
Tlag's the man for legacy's tbo , but on the impreza's there's a resonator delete ,its a black box in the drivers side wheel arch trim . It's supposed to make the air turbulent to create a better mixture.
Once removed it allows the air to be drawn from under the inner wing easier .
If not applicable on the legacy you could drill the air box (under the filter height ) and make up a cold air feed
