Sorry for the silly newbie question
Ok mate, well u reconnected it and went for a 5 min drive and it was doing it when I come back?
It's like an electrical clicking noise. Not misfiring at all
Does sound like a relay or solenoid as I know when you do diagnostics on a classic the fan relays and boost solenoid click to test themselves .
Did you fix the vacuum "T" piece as a leak in vacuum would possibly cause the boost solenoid to click .
It's more like a relay click g noise and very rapid too and the tee piece was replaced yesterday
Electronic faults are difficult to find without diagnostics and even then can be down to a bad earth or fault somwhere else .
Maybe try to find the particular relay thats clicking and one of the newage owners might know what it's for .
Or there is a blue tooth odb interface and phone app that some newage owners use , but unsure if you can wipe /read codes with it .
Hopefully someone who knows a bit more about newage electrics or the app will post .
As early classic mechanics are more my thing tbo
Ok mate thank you, it shouldn't be anything major as the car drives perfect. Hopefully it is something to do with disconnecting the battery and will sort itself out :/ I the meantime I will keep an ear out for answers. Thanks for all your help.
