Door card removal.....
Can someone let me know if there any 'hidden' screws which need to be removed in order to remove the drivers door card.
Pretty much the same for alo models.
One screw in the door pull then it will just pop off.
Start at the bottom corner and firmly tugg the door card towards you, then work around the bottom and sides pulling the door card away from the door, when it's loose lift it up and away from the door.
cheers, i'll have a go this aft.
Cheers for that, card off now to try and sort this window.
