exhaust bolt removal tips
OK people I've changed exhausts on other cars no problems, and while bolts on manifold to cat are not rusty by any means they just won't budge so any tips appreciated
Can't you get a 4" from underneath. ?
Long arm torque wrench ?
Soak em overnight on wd40 ?
Easy peasy......
All 5 nuts on my downpipe were corroded, rounded off and generally a pain to remove.
Bit of WD40 on them then get a ring or open ended spanner on the back and a Bolt grip on the front. Will come off easy as pie.
Irwin Bolt Grips £24.99 screwfix.
http://www.screwfix.com/p/irwin-bolt-grip-nut-remover-set-5-pieces/96028?kpid=96028&cm_mmc=Google-_-Product%20Listing%20Ads-_-Sales%20Tracking-_-sales%20tracking%20url&kpid=96028&cm_mmc=Google-_-Shopping%20-%20Auto%20and%20Cleaning-_-Shopping%20-%20Auto%20and%20Cleaning&gclid=CMvvkO3Rs8ACFY_MtAodwEAAtA
Heat works a treat, either warm up with a blow torch or similar.
Wd40 did squat lol, managed to cut lower bolt enough to put spanner on and break it but then fubar'd hacksaw blade lol, so wondered if I get a new hacksaw and remove blade slip over downpipe and put blade back in will I be able to cut other bolt
