Misfire......possibly...
Sound's like a v4 to me
It depends on budget and how much work you can do yourself (to keep costs down)
As I've seen quotes for £1,300 from some garages just to do head gaskets .
You could buy the parts and pay for the machine work needed to fully rebuild yours for about the same cost , just depends on your skill set and timescale .
as with all second hand engine's you have to take the seller's word for it's condition .
Unless buying from someone trusted or hearing it running .
Tuff choice and best of luck bud
On a low budget sadly :(
as for how much work, aside from machining (skimming, etc) I can it all......
but as I said, my budget is very low....as in ideally sub £500 :/
I use importcarparts for all my gaskets ect..
I suppose a standard full gasket set , bottom end shells and head bolts and cambelt kit wouldn't give you much change from £ 1k . As I personally wouldn't reuse any of the above if splitting the block .
Headsets will be a bit cheaper and some people do reuse the head bolts but if the cambelt rollers and tensioner are original I'd add a full cambelt kit into the equations .
thats definitely higher than my budget at the moment :(
