couple more questions
Evening all
I have had the Scooby a week now and have a few under line problems. So here goes
Dry wheel bearing any decent makes recommended?
2 port boost controller, where can I purchase 1 if ebay any usual sellers?
Also when I turn left a bit hard feels like the left wheel is dragging anything common tracking maybe?
Also the other nite I had the management light flash but didn't store a code??
I am planing to do the work the week end along with a timing belt kit and water pump. Getting it ready for a remap, I may chuck a clutch in too.
It's a bug eye wrx 52 plate
When I viewed it test drove it not 1 issue and I am very anal with this stuff.
With the bearing if its happening a lot id say be a hub chewing them but no way to tell until you get it out. As for make japparts is best bet.
Boost controllers I wouldn't recommend. Mine was disconnected I will leave it to the mappers. Personal choice but to many horror stories have put me off using mine now and my car originally was going to be a track toy though.
With the wheel drag feel maybe a sticky piston on the caliper buckled alloy wheel tracking like you say maybe just balancing.
With the ecu light unless its thrown a code up I shouldn't worry too much. Unless you get it more often [emoji4]
