EML fault codes
I have a 07 forester 2oxc the eml and cruse light come on every morning and stay on fault codes are P2444& P0413 I beleave they are air pump and valves and i wonder if they can be cleaned out as the are £1500 to replace from subaru can anyone can help?
Hello, quite a common problem a couple of other members have had the same issues, I'll try dig out the other posts for you. Could try getting a second hand pump or a remap of the ecu will be able to remove the fault codes for good, I beleive the pump and valves are only used on start up and getting it up to temperature
Thanks for your help
