Exhaust Gaskets Advice
Right I've been having trouble with my exhaust blowing in 3 places...
Lower up pipe - This had a new gasket but it doesn't seal it. What's the best move? 2 gaskets?
Down pipe to turbo - This wasn't replaced so got a new one on the way tomorrow :)
Lower down pipe - This wasn't replaced but now can't get one through suppliers, apparently it should be a bell housing (overlap) connection? Mine isn't, it goes together like other sections of exhaust (face to face). Apparently this isn't right? Had to search ebay and found the gasket I need.
Original genuine subaru gaskets should be fine as your headder outlet and turbo inlet will be stock size .
my brv used to have a cheap upipe that would only seal if you put 2 gaskets in , even then it would blow the guts out of the gaskets after a few months [emoji53]
But he was running 1.2 bar
Cheers for advice :)
