Sluggish Acceleration
2006 Forester X
I can even get up to 80mph. It feels like there is little to no throttle response after the pedal is maybe half way down. Please help.
Hi welcome, is your car a fly by wire system or does it have cable operated throttle, has there been any work Done recently on the front of the car ?
Could try reading the ecu to see if there's any fault codes stored and maybe clear them/ reset the ecu then go for a drive,
If it's a cable operated system have a look to see if the cable is hooked into the throttle body ok and the route of the cable back to the bulkhead isn't obstructed or had got kinked
Sent from my SM-G850F
If it's a fly by wire system it shouldn't have the throttle cable,
I'll dig out a pic of a newer foz engine bay for you as mines an older one and looks slightly different
can't find a good pic of a newer engine as half have a plastic cover on or have been modified.
So this is mine, I take it yours is right hand drive ?
If you look at the pic you'll see the circled area,it's a bit wonky as I'm using me phone, in the right of the circle you'll see the throttle body and a black cable that comes out down to the front of the car and loops back on its self to the rear bulkhead,that's the throttle cable, if you don't have anything coming from the bulkhead then it must be electrical,
Does that make sense ?
What's vdc ?
Sorry the pic you boosted won't show
It's the panel that runs diagonal right inside the door. It runs from the dash to the roof.
Ah right I'm with you, as for the traction control I'm not sure with the newer models I can't turn mine off.
I can see pic now [emoji51] I'd call it the a pillar scuttle/trim
No worries glad to have helped, get some pics up of your foz mate we always like to see more of them here [emoji2]
Update: this morning on a semi-cold start was super jerky and was barely able to get up a hill.
Sorry i don't know much about foz model codes is it a N.A version ?
When was the last time it had a spark plug change ?
as a misfire might cause lumpy idle and lack of throttle response, as mine fired up and drove on 2 cylinders with the same symptoms .....
When I accidentally plugged the left bank coilpacks in back to front [emoji51] [emoji4]
I actually just got the car and the mechanic at the dealership replaced plugs and wires.
Is it still under warranty ? I'd certainly ring the garage up or take it back if it's local and ask them to have a look. Might be just a simple split in a pipe.
I got a 3 year asc warranty. They've fixed everything they agreed on so I don't think they will do anything. I will deffinetly ask though.
I'd check vacuum leak- broken air hose or disconnected air hose.
Bad or disconnected spark plug wire or coil pack.
Maf could be an issue or a really dirty air filter but would have thought that would have been changed. But these arecthe things id look at 1st. If they won't look at it.
Update : According to my mechanic it is just a blown fuse for the throttle body. Going to pick it up soon, will update with the results.
Oh nice easy fix I wouldn't have guessed that [emoji4]
Ah yes, for anything electrical malfunctioning or not working, I always check the fuses first.
The pillar is called the "A" pillar.
