Coolant Temperature Sensor Problem! '99 Subaru Forester 2.0 S Turbo. Petrol/LPG.
I own a 1999 Subaru Forester 2.0 S Turbo - Petrol / LPG. The Coolant Temperature Sensor died several months ago. As a result, from a cold start the engine won't maintain tick-over; it stalls.  This occurs whether the car is stationary or in motion. To be specific, the engine can stall when I slow down to turn a corner, at traffic lights, etc.
A mechanic I've used for several years now ( a real petrol-head) has tried to identify the Coolant Temperature Sensor, but hasn't had any joy so far.  Because he hasn't worked on many Subaru's, he recommended I come on here and ask you guys for help... He suggested I ask, "Where is the Coolant Sensor for the Engine Management Centre located?  Is it underneath the Alternator?  If it is, then he has located the right one.
N.B. The sensor is a 3-PIN not a 2-PIN.  Whilst he had the sensor out I made a note of the markings on the sensor: GMA AA16 NTCL.  There are no other markings on the sensor.  I will attach some photos of the sensor and my Subaru.
I have contacted Hants Auto Fuels Limited (Unit 5/6 Hammond Industrial Park, Stubbington Lane, Fareham, Hants.) who installed the BRC LPG system in 2005.  To cut a long story short, they said the BRC LPG system can only be worked on / serviced by an licenced BRC LPG engineer.  And I would have to take the Subaru into one of their authorised garages / units to investigate which sensor it is and how the system is set up, etc... I related this to my mechanic and he reckons this is B.S.!
(According to the LPG Installation Certificate the equipment was supplied Alternatech.  The Regulator Make is a Prins VSi.  Make of LPG Tank is a Stako and is a 55LR Totoidal situated in the spare wheel well located under the boot.)
Can anyone offer any help, suggestions, advice or information, please?
Many thanks in advance.
post-2350-0-10854000-1422529349_thumb.jp
post-2350-0-51270400-1422529363_thumb.jp
post-2350-0-89674400-1422529649_thumb.jp
post-2350-0-90100000-1422529663_thumb.jp
That indeed the ECU coolant sensor
ICP do them & quite a few other sources too:
* worth checking with them to confirm part via reg-chissis-engine number prior to buying *
http://www.importcarparts.co.uk/parts_info.asp?id=4279&cat=0⊂=0&sec=0&var=0&dc=&gen=
http://www.ebay.co.uk/itm/Forester-2-0-2-5-Turbo-NA-98-07-ECU-Water-Coolant-Temp-Temperature-Sensor-/271365238379?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3AForester|Cars+Year%3A1999&hash=item3f2ea0ee6b
Ideally want test sensor impedance over varying temp & see if it seems working/in parameters.
Does plug-cable seem good. Bit of testing here good although sensor not over expensive if want chance it.
Plenty of other things it could be & plugging in  some diagnostics would be good to read faults & see what tenp signal the ECU getting if not flagging it faulty.
Hi Mr B,
The information you've provided is excellent! I'm most grateful to you!
Many thanks,
Nigel.
