PPP ECU flash
Hi all,hope all are well :)
I have a 2002 bugeye wrx and have replaced the back exhaust,K&N panel filter and looking for a safe flash of the ecu. I am ok mechanically ,but have no experience regarding flashing the ecu. Not bothered about pushing it to 280hp............etc,want it safe/reliable but a little extra poke. Not removed a cat but can be done if a must or even after the flash. Is there any one in the manchester/bolton area who would be willing to help me please. Of course cash waiting for their time and what they are happy with :)
Many thanks ven :)
Why does it need flashing ? Fault codes ?
or do you mean remap that is similar to the PPP map
Hi,sorry for late reply
Yes PPP re-map I beleive can be done flashing the ECU (could be wrong). There are no fault codes etc and runs fine . Had all belts and plugs done a few K ago.
Just wondered if anyone around the area might have it on their laptop :-)
Cheers
You need to have a ecutek based remap mate ,
There are a few up north , think stants is having his done by race dynamix who are mobile and well known
Been done mate went down the esl route as my97. Rick is in the lancs area and was having Andy Carr do his I think
Thanks guys,I was under the impression there was a map that people could use via the obd2 port. Maybe I am getting mixed up with open source maps. Sure I read up that it can be obtained and its a standard map(not custom like Duncan and Rob do). A basic PPP map with the few mods.
Looks like a custom re-map then is the only way. Mobile is best as I am not bothered about rolling road and read outs. Don't want to go down that road!!! As I know it never ends and things break (including the bank) :-)
There is open source available for new age carberric ? I think it's called. May be worth sending a pm to mfnick as he had his blob mapped and I'm sure he didn't use ecutek route
Ok,thanks for that stants :)
On classics the PPP is within the ecu and you swap them over
Right,maybe that was also adding to my confusion,i was under the impression for some reason it could be easily done via the obd2 with the PPP map being a generic one..................providing someone had the map or similar on their lap top. It does not have to be the PPP exact,just a similar map if makes sense.
Not unless they got mapping software like eculabs or datalogit
I would never ever try a generic map off someones laptop with these engines , unless you fancy spending a couple grand on a new engine build
Even the Apexi base map is shocking
Right ,much appreciated on the advice, will sort a re-map from a reputable place at some point .
Cheers,well got the ball rolling a little,ordered a boost gauge and pod for the pillar
http://www.ebay.co.uk/itm/221673198110?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Green to match dash
mount
http://www.ebay.co.uk/itm/150872627950?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
So i have a starting point and no where i will be going,of course to keep an eye on things to............and i like them :)
Once fitted,will look at mapping over next month/s.....................getting it done discrete without the boss knowing is the hard part :rolleyes:
