Hi, new to this forum, recently bought a 56 plate 2.5 XT Forester after selling my 98 2.5 legacy and after adding cataclean to fuel error code P2444 has appear.  Read through a few North American sites to get some info but a British perspective would be appreciated.
Hi mate welcome to the forums
I would clear the error code 1st see if it returns if you have not done so already, check all your fuses just to be safe I doubt it will be but it's covered :) and relays which is possible.
and as I'm sure you have read already what the fault is
bur here it is again :D
P2444 Secondary AIR System Pump Stuck On
Possible Causes
* Check the operation of the secondary
AIR pump
relay
Check the secondary AIR pump relay for a short to ground condition
* AIR combination valve has failed
* PCM
has failed
Setting Conditions
Engine running; Secondary AIR system active, and the PCM
detected a problem in the operation of the Secondary
AIR Pump
(it may be stuck "on").
This code sets in 1 Trip(s).
This code will turn on the MIL (Malfunction Indicator Lamp)
hello to all and thanks for the info.  I'll work my way through the fuses and relays first then follow other steps
I think that's the best place to start mate. Sorry I couldn't have been any more help then that. :)
