tfo35
hey lads i need a tfo35 for the forester
any about in reasonable condition
Stick a td04 on it the car will be fine
thanks for the tip but not looking for a different turbo  just a tfo35  like to keep it stock
Beat me to it rick I was gonna suggest the same [emoji16]
thanks for the tips but want a replacement tfo35 :) :)
Yeah mate I understand, I've had a bit to drink tonight so was only throwing the odd idea around [emoji16]
@ stants don't worry :)  its weekend :) :)
@ rick  thats a tat way over priced  for a little tfo35 !!!!  225£ to my door !!!!
are they hard to come by ????
bump for tfo
what is the goin rate for a tdo4 ( smallest version )
bump for tfo
About £50 to £70 I just sold mine as well.The Td04 is man enough for the job.Tf035 turbos are hard to come by
i was told today the small tdo4-13 is almost same size as a tf035 ( almost same size exhaust propeller )    is this true ??? and of  what  subaru does it come of  ???
i really like the very fast spool of the tf0 for towing etc
Not sure about the size i'll do some digging but the 04 is a great turbo spools up fast and gives good power just runs out of puff earlier than an 05
Rick has a uk spec foz and he swapped his tf35 for a td04 with no problems,
'borrowed from elsewhere' td04 on the left tf035 on the right b0637ff39ce0b4bd866f798ac5877010.jpg
You will have no problems with the TD04 turbo mate.You get more boost for pulling lol and you wont run lean trust me.I had mine checked on a rollers with a turbo swap with no tuning and my Foz was run flat out with no issues with a dyno print out to prove it
