Boost issues
Hi everyone I'm have problem with boost and vacuum hoses it looks like somebody at some point has hacked around under the bonnet and I was wounding if anybody know if there is a diagram out there that I can follow to make sure everything is connected properly its a 52 plate bugeye HELP
I know someone who will probably be along shortly with quite the knowledge of all things bugeye, I am sure he will be able to point you in the right direction
Thanks jay I've had a look and there are t-pieces cut in and there is s little l shape valve coming off the turbo that hasn't got a pipe on it I've got new pipe to replace the hole lot just need an idea of what goes where and if its correct the car seems to be not boosting correct somebody did mention putting an sti turbo on
That should be a great help looks like bonnet up tomorrow with laptop next to me trying to solve the puzzle thanks for the help much appreciated :-)
All done and connected as it should be thanks for all the help :-)
sounds like someone might have fitted a boost controller and not sorted it properly after removal, is it all working properly now?
