Road Angel hard Wire
I know this has probably been asked a million times
I want to hard wire my road angel
It came with a hard wire kit, that i assume you attach to the cigarette lighter ?
I dont see a problem unless i want to use the cigarette lighter to power something else then would it not be able to power both devices ?
Or do i attach it to the fusebox ?
392AB922-9BB9-4495-A20A-5FFA558C7683_zps
0DF67E33-6416-4A4F-9497-8E2A158963C0_zps
If you fit an in line fuse to the cig lighter should be ok, if not there's spare fuse holes in the box, do you have a piggy back tap fuse ?they just plug into the fusebox and already have an in line fuse
I dont have a piggy back tap fuse tap,
if i buy one can it go into any spare fuse ?
would the black just go onto any screw thats earthed ?
looks like there are no spare ones, which fuse should i piggy back ?
E2F4C5C1-0962-42A6-A529-FD07B3E9D4C3_zps
WTF is this i just noticed it
16C6DCC5-4DA6-4284-86F5-5AF8A265D83C_zps
2528799D-AAD5-4B2C-82C3-BAC27388E857_zps
Have a look for an add a fuse on ebay, you take out one of the existing ones pop the piggyback in then put the existing fuse back on top along with a separate on for the accessory.
Maybe the thing with tm on is a traffic master unit. Had one in my old van. A bit **** to be fair
Cant help other than link i have when i bought a couple(i did not use but no doubt will)
http://www.ebay.co.uk/itm/230652186731?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Just fit the fuse removed into the double fitting along with the one for device
I have just bought a detector this minute!!! Good idea having one,more so with all the cameras around me,nothing fancy at 1st
More for when i go into Wales to the van, where they love cameras!!!
Cheap n cheerful
http://www.ebay.co.uk/itm/171358178037?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Never had a speeding ticket.............you know what will come now :rolleyes:
Thanks for all the help guys !
its now fitted and sweet !
