Bouncing Tachometer (Rev Meter)
Hi guys,
I have a 2008 WRX and noticed today if I drop it from high revs (over 4k) and let it hit 0 e.g costing up to a stop, the Rev needle will hit 0 and bounce up to about 1-2k and then drop back to 0.
Not sure if this is a problem or not or what it means but thought I would ask.
Thanks for any help
Alex
Is it just the needle that bounces or the engine revs too?
As far as I can tell its just the needle and not the revs themselves.
Earth fault on the clocks ? Or maybe something to do with the wires you found last night ?
Don't think it's always done it and I haven't changed any wires just looked at so not sure why it would start doing that.
How would I check for an earth fault on the clocks?
Btw everything else works fine car drives fine as far as I can tell.
Ah ok you'd have to pull the dash apart and have a look for a loose connection [emoji53]
Oh that dosnt sound like much fun :-(
