headlight swap
i want to change my headlights from these
11080917_10153875635751002_1628918724686
to these ones will it be a easy swap over to do
will there be any wire cutting etc and they were on the optional extra on the receipt when bought from subaru new
I swapped mine on my blob from standard to aftermarket and there was a lot of wire snipping and trying to figure out with a multimeter what went where. but i couldn't tell you about if those lights are the same.
hope that helps a bit :)
should be plug and play if they were OEM ones
Need inserts too for around the grill and lights but should swap easy enough.
i prefer the morrettes make it look alot less fugly
i found the look i want for the front of my car
185381_10150753223925257_6778115_n_zpshu
i want the headlights,grill,front bumper,and the bit that goes around the lights and runs along the top part of the bumper
Are they the prodrive lights your swaping to.if so sould be simple.if your buying aftermarket light then be carefull, I put some aftermarket halo lights in my blobeye, after about 3 days the halos would flash as the connections in the lamp was rubbish. Then when I jet washed car 1 of the lenses fogged up as the seal on them was rubbish as well.lookt nice but build quality and material used was rubbish.
think so not sure what lights they are as im new to the subaru scene so still learning :)
A much better look I feel.... Im currently changing my bugeye to prodrive the exact same as the picture above ☝
I have those jdm lights for sale if your after a set as also have the morettes too :)
How much you wanting for the jdm lights.you got a picture of them,thinking off swapping to them after a sell my morrettes as think they look more modern,are they plug n play ?
