Boost solinoid issue
Hi all i have a v2 import sti. I have a fault with the boost
Solinoid the on board diagnostic is showing a fault that there is no
Signal from it ive replaced the solinoid to no avail
The car had a small engine bay fire which fried a couple of wires they have
Since been repaired but just cant get to the bottom of this issue
The car will only boost to 0.5 then it fuel cuts any help would be great or if anybody has the ecu pin out
Thanks tony
You should find your ecu pinout here
https://www.xcceleration.com/pinouts.htm
Open whichever diagram is for your car and check what the location of the boost solenoid wires are on the pinout !!!
Use a multimeter to check for continuity by putting one probe in the correct pin on multiplug then put other probe at the boost solenoid plug end ,multimeter should beep if ok and repeat for the other wire on solenoid plug too
This should tell you if the wiring from ecu to the solenoid is ok
Take it your using a apexi ecu ?? Savage
Also as temporary measure try looping the pipe from the wastegate actuator straight to the nipple in the turbo compressor intake
This will check your turbo is boosting up to wastegate pressure (std boost)
Will also help to eliminate were the problem actually is
Yeah I'm running apexi with the separate lead to another uprated map sensor (off a my 98 onwards classic) , but the standard map sensor wiring has to still be plugged in even though the oe map sensor vta [emoji15]
Yeah just spotted the standalone map sensor just helps to know
Take it all the settings on the power commander are ok in terms of boost setting etc
Been a while since used an apexi tbh
Have you tried cleaning the boost solenoid aswell as they get bit gummed up over time quick squirt of wd or brake cleaner down both outlets usually helps
Yeah it's all been mapped in [emoji6]
Just thought I'd remove the oe sensor the other day to neaten up the bay a bit .....
Only boosted to actuated pressure (0.5bar) so I refitted it and I'm back to 1.5 bar again .
Have a squint at my v1sti build thread on here if you get bored on your lunch break [emoji4]
Will have a peep later on savage but I'm a busy lady hahah as in work :)
Just sneaking a quick min or two to reply on here :)
Looks a clean car tho
