Impreza wrx rad fans wont cut out ???
Something's up with my 2004 impreza wrx after a 30 min or more drive the fan doesnt cut out anymore and the temp gauge on dash is reading slightly lower than normal, the only way to stop the fan is to turn the key completely off, iv just had a new cambelt, all new pullys and tensioner and water pump and thermostat and radiator fitted ?
Iv had it pluged in and no faults are showing up. Engine seems to run okay, no probs starting or idling.
Iv looked online and am thinking my engine coolant sensor is faulty, do you think those problems could be a engine coolant sensor ?
Please help, rather worried about it
thermo switch gone ? Controls the fans on and off, not sure if yours has one but may be worth having a look,
Okay thanks i will have a look
How's the coolant levels looking ? Maybe an airlock somewhere, are you getting heat from the cabin heaters?
Yeah getting heat in cabin, coolant hasnt moved since i was checking it after the work was done, its slightly above the max line cos i put abit to much in.
Is that max when hot ?
Yeah goes bout inch above max wen hot
Iv noticed somthing else that happens, wen the fan is running after iv pulled up somwhere, the fan runs fast then cuts down to a lower speed and then it used to cut out after about 30-45 seconds. Maybe it could be just a switch the turns it off all together has gone ???
You have aircon ? They haven't wired the wrong one up ?
The bloke that did all the work said it was all very clean for the age so dont thk corrosion is it, wires look gd aswel.
Yeah iv got air con but i always keep it off, apart from the air con belt he wouldnt have touched wires for the air con would he ?
No bit if he'd taken the rad out he'd have unclipped the harness for both fans
I dont know myself but if he had done that wouldnt the fan not start atal ?
I'm just clutching at straws really maybe a bad earth or shorting out, are all the fuses ok ?
Yeah iv checked the fuses, wondering bout the relays now, might just change them to see if it works
If not them i thk il try the coolant temp sensor next
Do you have a multimeter ? Will make life a lot easier. Hope it turns out to be something simple
No dont have multimeter, yeah same haha, il let you know what happens, thanks for all your advice stants ;)
Anyone else wiv any fews on my probs ?
Rite iv got a coolant temp sensor coming and will try that.
Iv noticed somthing else odd thats happening, if i turn the heater fan on in the car it make the temp gauge on the dash read correctly again instead of a bit low, and when iv pulled up and am waiting for the fan to turn off which it doesnt, if the heater fan is on the coolant fan stays on full blast if i turn off heater fan the coolant fan goes to half speed and then still wont cut off.
Any ideas anyone ?
