Piston slap ?
Just a quick one if your car has piston slap would you use more engine oil my car has a knock in morning for a little bit till it get up to temp but I did have a noise like this a few weeks ago start off like this and turned out to be something loose in the engine my car only has 42k on and is a 2.0l blob wrx maybe it's just me and the bracket is starting to come loose again thanks for any advice
Hi mate, mine slaps like it's going to jump out the engine bay. But mines a my97 with 130k on and the 97 cars have the worst reputation for doing it, the piston skirt design was changed after.
Car uses no oil at all and I've put full & semi synthetic in over the last couple of years,
At 42k I wouldn't expect yours to slap too much. What oil are you using & any mods done have you had the belts changed yet ?
Could be the belt tensioner if you look on YouTube there's vids showing it makes a knocking noise when worn
I just got car 8 weeks ago come with a fresh service so not sure on what kind of oil was used probably just what grade subaru recommend I got the garage to put a timing belt kit on and new water pump car is stock I done about 1200 miles after I got car and had a noise that stared off like a knock then a rattle as the car reved put it back in and thay said something had come loose maybe it's just that starting again av now done 2200 miles since a got car and it's never used any oil just thought if your car had piston slap it might use more oil just so it can be ruled out
Nah don't think they do it's only the pistons rattling around when cold, I'll post up a vid of mine should make you feel a bit better, does it go away when warm ?
Have a look for subaru rod knock on ytube to see what that sounds like !
Yes it went away when it street to walm up after about 5 mins but it was not doing it a week ago sorry if a sound thick but don't know a lot about cars a just know a like cars ☺
My car slaps a bit more on a cold morning not as bad as Stants car though but it does do it. same with the 55 plate but does seem a lot less quieter though.
Al see if a remember and Al get a video in the morning only seems to do it then and only since it got cold maybe am just being paranoid
Id say so mate lol. We've all been there. [emoji106] I still listen now [emoji1]
I'm the most paranoid ! This week my gearbox has stopped going into gear, and along with the slap I'm at my wits end
Am the same always think the worst and a hypo with cars
Ive got a little piston slap when warm it stops.Mine doesn't use oil :)
a 2003 blob wrx shouldn't have piston slap, they use Hypereutectic Pistons. they are stronger than cast pistons and have more silicone in, but not as strong as forged.
Hypereutectic Pistons don't expand and are machined to very tight tolerances. forged pistons expand when they get hot (hence the slap when cold) and once warm, are very strong
my blob wrx is running 330bhp and 109k on the clock, not even a sign of a rattle on start up.
I think they need to investigate further
