coilover suspension
I have only heard good things about BC so thats my personal option.
As tidgy said just make sure you get the right spring rates for you, you don't have to get the ones that come with the shocks you can request softer ones and they'll re valve the dampers to suit
what iam going to do is phone up scooby world and see what they say
Have a look at scoobyparts.com they have a bit of a guide on the bc's and spring rates
on scooby parts they say that the popular are 6 at the front and 5 at the rear
Are you going to be using it as a daily ? I'd be inclined to go 5/4. I was just as confused as you to working out best rates, gave up as was even more work on the foz bought a set of shocks & springs instead
Ah well the 6/5 would be ok. polly bush the suspension parts as they need replacing and Watch your teeth rattle out [emoji51]
i will buy that set then
and i thought about polly bush the whole lot once i got the suspension sorted
going to buy front an rear strut braces aswell
Nowt wrong with them mate, some say it's a waste of money but I definitely felt a difference when I put mine on
A few bits more if you really want
would the lowered suspension and the strut braces make the car nice and sturdy
Yep you'll see the difference, you can get under body braces for the front and rear if you want to go for the full works
Nice looking braces there mate, as for other braces there are a few more you can get ....
- fender braces
- reinforced pillar bars
- 4 point under floor brace
That's just a few see the link from tuningdevelopments :) not sure how many Bruce for scoobys but you get the idea :D
http://www.tuningdevelopments.co.uk/index.php?cPath=4_25&sort=5a&page=2
James
think i will stick with what im buying as i can always buy more bracing in the future
At the end of the day ultimately all your doing with the bracing is adding weight, so just strut mounts will see a big improvment. Unless your tracking the car it's not really necessary.
thats one thing im not doing is tracking it lol im not going for fast im going for slow and low look :)
Im looking to buy a set of coilovers myself. Will i need adjustable camber arms to avoid too much camber?
