Black soot out of exahust
Hey guys
just concerned by some black soot that’s built up over 2 weeks, theres no black soot
when its on and when I am driving, I haven’t noticed any driving hard either.
Its got a recirculating dump valve, straight de cat exhaust, remapped all done by Scooby
clinic
Should I be concerned that my engine or turbo is about to go or is it normal to build
up over such short time ?
8EF6F5F2-70ED-42EB-8C27-F0A113C4B873_zps
A9D57B72-C2F6-4BC9-B90B-84953C4BC9F3_zps
When was the map done ? chances are it's running a little rich on start up shouldn't be anything to worry about, white when warm = bad. blue anytime =bad
was remapped about 3 months ago
What do you mean white when warm, and blue anytime = bad ?
I have dash command what settings should i use to monitor this ?
He means the smoke out of your exhaust. You get white smoke on a cold start up which is normal, if it keeps coming out when the car is warmed up it's not so good. Also blue smoke is very bad as it means oil is being burnt.
Blue smoke = oil burning
White smoke = water
Black smoke = fuel
unless your seeing lots of black smoke out of it i wouldn't worry to much, if in doubt just give clinic a bell and can always run it back to em to give once over.
Sorry I thought I'd replied stupid phone !
Cool will pay extra attention tonight
I have the dash command app, i dont understand half the settings what should i have on my display ?
I guess you can have what ever you want,can you load different skins up and customise them ? If you can I'd have oil temp oil pressure,water temp and boost,
Those are the main ones to keep tabs on really
thanks guys
will keep a very close eye on it
i think its just the petrol being rich
Hi,why doesn't the 2.5 forester have a boost gauge,and is it hard to fit one,or am I being silly,again.
Non of them come with a boost gauge as standard, there was a tick box on some sti option sheets from new but that's about it, really simple to fit one hardest part is getting the wiring through the firewall grommet
Ok so i watched the smoke very carefully at 7am it was white lots of white smoke first start up i watched it for 5 minutes :
B1B261F8-9021-4A1E-98E7-0F773079CAB5_zps
CFEF619B-4D2F-4561-9A36-E72DE6255CF8_zps
17FD0B46-74C6-4594-9319-24106E46EB30_zps
88B41B07-B65E-4503-8BC0-9067A5544D93_zps
At the 6th minute it became clear with no smoke, soot, i drove it normal for 5 minutes, then very hard, no soot or anything smoke related
Looks like the black soot was indeed built up over all the hard driving
  • 4 weeks later...
Yeah sounds totaly normal.
thanks puts my thoughts at ease
