TPMS
But from day one the orange light of the tyre pressure monitoring system is on. The dealer tried to reset it, but no joynono.gif They said that Subaru says it is a "known" problem and a chief engineer from Subaru needs to come and do this ponder2.gif
So have you had this on wince the day you picked it up? Ask them to swap the car for one that works if they can't fix it, see what they say about that
This happened second day I had the car. I let them know straight away.
To be honest I'd rather this system was deactivated, as I don't see its real use, other than some conformity to regulations
So have you had this on wince the day you picked it up? Ask them to swap the car for one that works if they can't fix it, see what they say about thatI
I thought about this. they'll have to remove my private plate as well!!!!
Tell me about it. I had trouble with a wheel speed sensor on my golf gti bringing this light up and ended up with a fault on the ESP control unit. I can't see why they a subaru dealer can't fix something that should be straight forward for them
I would'nt worry about that they would never contemplate swapping the car for a fault such as this , tell them if its not sorted asap your going to trading standards .
Its worked for me in the past
