legacy mk3 caliper bracket help
hi ppl I changed disks and pads on legacy mk3.first time ive ever done anything to the car in 5 years lol.its a work horse.i noticed one of the rod things was stuck in the caliper bracket.after losing my knuckles,gashing my arm and murdering my wife.i tried everything under the sun to get it out.20 cuppas and 4 spliffs  later I had it heated up and in vice and the !Removed! thing snapped inside.now I'm not clued up on these I need help to find a new bracket in the uk one cheap enough for me not to remortgage.any help or links would be appreciated thanks
Can you post up a pic ? The only things I can think your refering to would be the caliper mounting bolts or the carrier to hub bolts,
Unless you mean the pistons ?
In which case you'd be better off getting an exchanged recon caliper
I need this part and im mobile at the minute sorry for multiple pics
Ah ok, I'll have a dig round the web for you www.importcarparts.co.uk may have them, if not it may be a new hanger, as it must have been cross threaded to have snapped [emoji26]
Lol I'll edit post for you
Looks like you'll need either number six or eleven depending on what side of the car that's off
No6 is guide pin part no 26228AC000 or 001
No11 is lock pin part no 26228AC010 or 011 I wouldn't go on my word as this is what I've pulled from some online diagrams but should give you a good start if you contact your local subaru dealer
Great diagram thanks i snapped the number 6 inside number 15 as it was siezed so now need the number 15 part
Do you know part number for #15 that would help lol thats should be easier to shop about as i have no idea what its called.mate says its a caliper bracket but didnt find it online thanks
What year is yours ? Not to clued up on legacy business
Have a look on www.opposedforces.com that's where I pulled the data off fo the other part no's but I may have given you the numbers for mk2
But if you go to the legacy section you'll be able to get the right year and pn
here's a complete slide pin kit >
http://www.ebay.co.uk/itm/SUBARU-LEGACY-MK1-2-3-1989-2003-FRONT-CALIPER-SLIDER-PIN-KIT-GUIDES-BCF1393D-/231306192072?hash=item35daec64c8
won't be much use if current cailiper mount bracket not serviceable.
You should find a used caliper complete with bracket on eBay or a good breaker for 25 to £35 !
I can't get on the opposed forces site at today, there's place near me that just breaks subaru's I'll post up link
Im over the moon guys my brother has spent the last hour heating it up and its out yippeeee.thanks stants and i ordered the pins you put up.apreciate the help lol. Close this post or thread thing if you want bye all
Sent from my stupid iphone
Thanks mr b
While im here can i ask why does my car go so slow like no power until 3000rpm then suddenly pulls?
Same car mk3 legacy estate
Firstly ive changed air/oil filter,spark plugs.friend says it might be fuel filter but it also does it on lpg.do lpg and petrol run through same filter?and where the hell is it lol ?
