Hi All,
I was wondering if anyone knows if you can buy an induction for the 2008 RX hatchback? Or if anyone with the same model has any other recommendations.
thanks,
Why ?
Panel filter will be more beneficial
Just looking at doing some cheap mods and improvements until I can afford a WRX on the insurance. What panel filters would you recommend?
Cosworth or similar dry ones are better but they need replacing at normal service intervals not sure of yours has a maf or map sensor if it's the latter you should be ok with k&n kits too
It does have a sensor just after the air box.
