Strange Sound
Hello guys,
I have recently had my gearbox rebuilt and a new pink clutch put in, all bedded in with no problems but...
I have been hearing some sounds I haven't experienced before.
when slowing down (engine breaking) my car (2003 impreza WRX Blob) makes a "fff  ffff ffff ffff ffff" sound, this stops if I apply any throttle.
sounds like air or as if there is a cloth attached to the drive shaft spinning about.
any ideas?
Kind regards
Chris
Bit like this
Have you checked the tyre pressure like vid ?
I shall do it when I can, seen (just now) some people recommend this.
got some new tyres going on in a few days so will make sure i'm balanced, aligned and all that jazz when they go on too.
How much did the gearbox rebuild set you back? I really need my box doing just dreading it...
Okay that doesn't sound so bad! Although I think it's more my diff than box if that makes a difference.
majority of the cost for mine was in parts, had 3rd and 4th gear set replaced with some new bearings and syncromesh kit, the parts for that were like £600 !!!
(luckily my warranty covered it)
Gaulson, did you speak with g.e.a.r.s in Liverpool ?
I didn't no, my brother has a place that can do the refurbish and he does the labor (at mates rates). The day is looming ever closer!
Ah I forgot about your brother, lol always good to have someone on the 'inside'
Its not the tyres, oil is at right level. It's odd as it doesn't happen all the time. Happens more after a hard run or high motorway speed and the going back to a 30 limit and using engine breaking around low speeds
Sent from my D6603 using Tapatalk
That sir is your clutch , i have the exact same noise and i also run a exedy pink clutch kit
Is it a problem. Is there something I can do to fix it?
Yeah get rid of the exedy, i have been reading a lot of topics about the pink box clutches and they made a bad batch of pressure plates apparently , i am swapping mine out this week for a helix unit
Cheers mate :)
Sorry man i know it sucks especially after the agonising bedding in jerking process. Wish the helix was a bit cheaper
It's okay mate, needs sorting. Hopefully it's still covered under my garages warranty
I may try the competition clutch
Strange I've only ever used exeedy clutches and never had an issue. Not saying you're wrong by all means sharing is important. So I'm interested to see the feedback of the alternatives. Same thing happened with fuel pumps I rate RCM more than the other leading brands. :)
I mean It did happen after I changed my clutch, but I don't know. Also judders more than I expect it should
Oh yeah it will judder like hell, mine would shake the whole car, Its ok now until i come off track then its a nightmare again.
I heard about the dodgy batch of exedy clutches. That link I posted a few weeks back from Aztec, a local member bought an exedy from them but Aztec refused to send him a pink box because of the amount of returns they had for faulty pressure plates. They honoured the price and sent him a higher spec clutch kit.
They did same to me with a pink clutch. But I wasn't to happy as they tried to put me onto a higher priced clutch, which I would have bought if I wanted to pay more
