Move to the darkside
Hi all I'm new to Subaru wrx (moved over from st225 focus) just bought a 2001 wrx ,need some tips ,have got in panel filter catback pipe 3prt valve and looking to get a remap ,can anybody recommended and what sort of bhp should I expect and any other mod with out going Otto ,thanks
Td04 will max out at 280ish
Sti upgrade vf35 will see 330-350 yet retain your ecu
Thanks guys ,is it worth putting a uppipe on and leave the down pipe cat on ? Is it a job I could do ?
Up pipe is a must. The cat inside has tendency to break apart and destroy the turbo. You won't need to buy anything, just take it out and pull the guts out and fit it back :) Great cheap mod B) It is doable DIY, if you are handy you could do it in 2-3 hours. You could also remove your 2nd cat from downpipe and leave only one. It will get you thru MOT if thats your concern ;)
OK mate ,I would need long drill hammer screw driver ,I have a jack Axel stands etc,just thought it would be good to do that and fit the still 3port valve before remap ? Also does anybody know the rubber vacume pipe dia I need to use ?
