More power from a sport
Hi, I have a 99 impreza wagon none turbo, I have a replacment engine waiting to go in, however before I do how can I get more power from it without spending silly money, and yes I wish I had brought a turbo but I'm stuck with this now so wanna squeze as much out without going stupid money as when it comes to sell time I don't wanna loose to much money..
thanks in advance
Tbh nothng really mate Mybe an induction kid, BP Ultimate fuel, get a we bit more hoak out of it anything from 2HP to 20HP, best you can do is do a turbo engine swap,
Lots of money for little gain to be honest, I'd save the cash and get a turbo engine or full car
As posted engine performance gains will be limited - spend money on chassis and brakes, shed as much weight from the car as you can to improve the power to weight ratio this should enable you to carry higher corner speeds etc
ok guys thanks for the input, keep going the way I'm going then :)
One thing the sport lacks over the turbo, bar the obvious, is rear disc brakes and rear anti roll bar, these additions would make a good upgrade, also if you upgrade the front calipers and discs to those off a bug eye wrx you will gain 4 pots, I've done this upgrade on my 97 turbo and it's quite an improvement, also look into a brake flex stopper, tegiwa make them as do other companies, again a cheap but worthwhile upgrade
Not to mention all these parts can go on a classic turbo if you decide to upgrade in the future
yeah definatly want to upgrade brakes these single pots are terrible, but would 4 pots not be a little much for a sport brake flex stopper what is this sorry if I sound a fool but you only learn by asking lol
The better brake force you have the later you can brake into a corner thus carrying more speed into, plus you slow quicker so can get on the power sooner too
A flex stopper stops the servo from flexing on the bulkhead when you hit the brake pedal, subies are made with thin metal so the bulkhead moves considerably when braking, a percentage of your pressing the pedal is lost through the flex, a stopper shouldn't cost more than £50 and you will be very pleased with the difference
change the spark plugs and ht leads and poly bush as much as you can afford. As said turbo is the way forward for power but when racing a turbo have the upper hand. Talk about limitations. Race until the tank is empty I bet you win every time :D  ;). I had 8mm ht leads and spitfire 4 plugs and did feel a bit of a gain but I also had a filter and exhaust. I poly the back bars. Just remember what you drive and allow the turbo's to go and say you won't do that when I get my turbo.
I have done a conversion from a non turbo to turbo myself and it does involve a lot of work, if need be I can give you a hand verbally on how to go about doing it. It's easy enough you you do everything in order. I have everything you need here, accept from a wiring loom which you will need to change.
Sounds like Gaz might have some know how about him :)
yeah been having a read up and the hard part is the running gear, so pretty simple to do, but can't do a turbo conversion due to funds, found out I'm having a baby so funds are now.limeted should have the cash to put the new engine in do the brakes, get induction sorted and maybe get some better suspension depending on price but everything else is gonna have to either wait or be done slowly, good thing is I've got this car for at least a year so plenty of time to play with it lol
Wow well Congratulations on the baby hope all goes well. So on that note I think Turbo and break's conversion you have to think about safety and sensibility first.....
It's ok I put that incase your Missus was reading over the shoulder (Quick check)  ;)
Ok so if it's safe read on :)
1st of all build a list of things you need like bigger turbo full through injectors if we can help we will. If all else fails just come here and look at this
http://uk.subaruownersclub.com/forums/topic/1710-subaru-body-paint/
Non turbo engine comes out
Non turbo inlet loom comes out
Non turbo petrol tank comes out
Non turbo suspension and brakes come out
Turbo things go straight in lol
Yes it will Ninja, everything from a turbo model is a straight fit, what year is the wagon?
Just seen it was 1999 mate, yes sti suspension will fit
I can sort you out with whatever parts you need buddy,
Not that dear mate if I'm honest I thought it was about £30? I've colourd wrx suspension aswell lol
