Car is dead after jump start
It's strange. It sounds the same as when I had it. Pipe breaks after turbo, floods engine then won't start 😛 Nothing beats solving it and hearing it run again.
Do love an earth issue.
  • Replies 75
  • Views 7.5k
    Check cam and crank sensors haven't been unplugged by accident while disconnecting the battery. Check the fusible link ,it's a bit of wire with a spade connection on either end in the under bonnet
  • As savage says 👍 this should also help! And for cam Sent from my HTC One_M8 using Tapatalk
    Did you disconnect the battery earth or just the positive side? It seems strange that it's happened after welding How do you know it's got fuel and have you done a ecu reset? Might be worth C
